Retrofit spindles from EMAG: Full performance - maximum stability
EMAG offers a comprehensive service for used machine spindles. This ranges from a flexible repair program with various options to precision testing prior to commissioning. Many spindle types are available in the EMAG warehouse for quick replacement.
The spindle - an indispensable component of machining quality
Many EMAG machines have so-called pick-up spindles: The spindle picks up the component from the automation (shuttle, belt, etc.) and guides it into the work area, where machining starts - with speed and precision. This assembly is critical to guaranteeing machining quality and is subject to a certain amount of wear.
Repair program with options
In this context, the "Spindle Assembly" area within EMAG Retrofit is particularly important. Among other things, it offers a comprehensive repair program for customers' own spindles, using only new parts or reconditioned components in original quality. You can choose between the “Basic Repair” or “Full Repair” service packages.
Detailed view of a disassembled EMAG spindle on a workbench with visible precision components and maintenance tools
Precision work during spindle repair: EMAG relies exclusively on new parts or reconditioned components in original quality.
Basic Repair
  • Cleaning the spindle unit
  • Replacing the bearings
  • Replacing the seals
  • Test bench run
Basic Option 1
  • Engine overhaul
  • Test bench run
Basic Option 2
  • Replacement of the linear unit (Z-axis)
Full Repair
  • Cleaning of the spindle unit
  • Replacement of bearings
  • Replacement of seals
  • Repair of hydrostatic bearings
  • Engine overhaul
  • Replacement of rotary encoder
  • Replacement of linear unit (Z-axis)
  • Test stand run
Full Option Spindle Unit
  • Cleaning of the spindle head
  • Repair of the feed drive (Z-axis)
  • Replacement of the length measurement system (Z-axis)
  • Replacement of the hydrostatic components
  • Restoration of the geometry
Your advantages by “Basic Repair” and “Full Repair” service packages:
  • Flexible, transparent and cost-optimized
  • “Fast Lane” processing possible
  • EMAG support during disassembly/assembly and recommissioning
  • Perfectly overhauled spindle including extensive testing (concentricity, tightness, test stand run, etc.)
  • 12-month manufacturer's warranty for reliable production
Comprehensive audit
Subsequently, a recorded initial commissioning at EMAG - before delivery to the customer - ensures maximum quality and process reliability. The grease distribution run within the spindle is checked and a precision run-in cycle and endurance run are carried out in accordance with EMAG standards. The result equals the quality of a new spindle.
Replacement spindles from stock
In addition, EMAG guarantees its customers a high speed, for example in emergencies after a collision. As a result, the assembly must be replaced quickly to avoid long downtimes. For this purpose, EMAG has a central spare parts warehouse that stocks many standard assemblies such as main spindles and turret units.
Retrofit spindles from EMAG have the quality of a new spindle.
Spindles from stock
The EMAG spare parts warehouse stocks many main spindles.
Advantages
  • Recorded initial commissioning before delivery
  • Modular retrofit with various options
  • New components or reconditioned parts in original quality are used
  • Spare spindles for quick solutions from stock
We are here for you!
Technical Hotline
+49 7162 17-4300
service.salach@emag.com
Global branch offices
