EMAG retrofitting machines from stock: The perfect foundation for many production tasks
Are you looking for a customized and cost-effective solution for your production task? Retrofit machines from the EMAG warehouse could be the solution. They are precisely configured and modernized. In addition, the large EMAG warehouse is an ideal location for any retrofit process.
EMAG always has a wide range of used machines in stock
In principle, EMAG always has various used machines in stock and is also constantly purchasing additional models. They are cleaned and overhauled by retrofit specialists - including the replacement of worn or damaged assemblies. Original parts are always used.
Modernized solutions are already available
The specialists also modernize and expand many machines, for example by introducing new control technology or additional tool processes, modernizing the entire housing and much more. For example, a turning machine can be transformed into a turning and grinding center and a 40-year-old cylindrical grinding machine with a hydraulic drive can be made into a state-of-the-art solution with servo-electric axes.
After modernization, the result corresponds to the performance of a new machine. Incidentally, in many cases EMAG also carries out these measures proactively and without a specific order. When a customer asks for a specific machine, chances are it is already available in the warehouse, modernized.
Central assemblies always available
EMAG's large spare parts warehouse with all central assemblies and over 20,000 spare parts means that many retrofit processes can be done at the customer's plant, allowing items like damaged spindles to be replaced very quickly.
Advantages
Technical Hotline
+49 7162 17-4300
service.salach@emag.com
