齿轮刀具磨床
HRG 350
  • Module range: mm 0.6 - 10.0
  • 工件最大直径: 300 mm | 12 in
  • 工件最大长度: 870 mm | 34.5 in
HRG 350 – Profile grinding machine for hobs
The HRG 350 profile grinding machine for hobs is suited for the manufacturing of all kinds of different hob types including helical hobs and threads.
Top quality with minimum cycle times
Thanks to our long experience in the manufacturing of high-quality gear cutting tools, we can provide the perfect machine for the customers who wants perfect final products.
The EMAG SU HRG 350 hob relief grinding machine is especially suited for the manufacturing of all kinds of different hob types, including helical hobs and threads. The machine guarantees top quality results with minimum cycle times.
Grinding methods:
  • Profile grinding
  • Creep feed grinding
The HRG 350 can accommodate all grinding wheels currently available on the market.
优势 HRG 350
  • Flexible with internal dressing device
  • Minimum cycle times
  • Accommodates all grinding wheels currently on the market
  • Siemens 840D CNC with mobile operator panel
  • The X and Z axes are directly driven by digital linear motors with flat prismatic guides
  • No mechanical transmission or backlash
  • Profile relief grinding of solid hobs and form cutter disc
技术数据
Module range
0.6 - 10.0 mm
工件最大直径
300 mm
12 in
工件最大长度
870 mm
34.5 in
Module range mm 0.6 - 10.0
工件最大直径 mm
12
工件最大长度 mm
34.5
滚刀最大直径 mm
12
Helix angle degree Grad ± 45
Distance between centers mm
34.5
Length to be ground, max. mm
17.5
Grinding wheel diameter range (relief and profile) mm
1.5 / 4
Grinding wheel diameter (threads) mm
8
砂轮主轴转速,最 m/s 0 - 45
Work spindle speed, max. rev/min 100
Stroke speed, max. str/min 300
Connected power, max. kVA 83
尺寸(长 x 宽 x 高) m 5,28 x 3,38 x 2,89
