齿轮刀具磨床
GS 400
  • Module range: 0.5 - 15.0
  • 工件最大直径: 400 mm | 15.5 in
  • 工件最大长度: 90 mm | 3.5 in
Tool Resharpening Machine GS 400
The GS 400 Tool Resharpening Machine is designed to sharpen shaving cutters and to grind master gears using the generation method.
GS 400 - Top Efficiency and Versatility
Designed to sharpen shaving cutters and to grind master gears using the generation method, the GS 400 tool resharpening machine is the fourth generation of its kind and sets new standards in terms of precision, reliability and user-friendliness.
EMAG SU interpolation software calculates the profile to be grounded and coordinates the linear movement of the transverse slide with the rotary movement of the work spindle. The resulting roll motion is steplessly adjustable in terms of the roll diameter, and indexing blocks are no longer required.
Roll motion and index movement are now numerically controlled and both generated by the same motor. All movements are actuated by linear and rotary digital drives. An integrated measuring unit automatically checks the quality of the first tooth ground without having to unclamp the workpiece and waste precious time.
The GS 400 tool resharpening machine is available with an axis X11 CNC. This new axis makes it possible to grind larger tooth widths whilst enhancing the quality of the finish. Moreover, machine set up is also quicker. Why set yourself limits? We look forward to illustrating you the advantages of the new GS 400.
优势 GS 400
  • Minimum set-up times thanks to the HMI
  • Reduction of runout errors
  • Easy and fast workpiece change with quick-change mechanism
  • Integrated checking unit
  • Grinding of shaving cutters
  • Grinding of master gears
技术数据
Module range
0.5 - 15.0
工件最大直径
400 mm
15.5 in
工件最大长度
90 mm
3.5 in
Module range 0.5 - 15.0
工件最大直径 mm
15.5
工件最大长度 mm
3.5
最小工件直径 mm
2.5
Face width, max. mm
3
No. of teeth unlimited
砂轮直径 mm
25 / 30
Stroke rate of work spindle slide mm
0 / 3
砂轮主轴转速,最 1/min 0 / 900
Max. stroke of vertical slide mm
10
Helix angle degree degrees RH 37 / LH 60
Pressure angle range Grad -5 / 30
Dressing speed mm/min 0 – 500
