成形磨床
G 375 H
  • Module range: mm 0.5 - 15.0
  • 工件最大直径: 375 mm | 15 in
  • 工件最大长度: 870 mm | 34.5 in
Precision Grinding for Gears, Worms, and Rotors
The horizontal gear grinding machine G 375 H is ideal for precision grinding high quality parts such as gears, worms, screws, and rotors.
Gear Profile Grinding Machine G 375 H
The G 375 H horizontal gear grinding machine delivers high-precision grinding for external and internal gears, worms, crown gears, rotors, screws and more. Designed for versatility and efficiency, this universal machine is the ultimate solution for manufacturers seeking top-quality gear grinding results.
Applications of the G 375 H Gear Grinding Machine
The G 375 H is engineered to handle a wide range of gear grinding tasks, making it suitable for:
  • External and Internal Spur Gears
  • Helical Gears and Crown Gears
  • Worm Gears and Splines
  • Ball Screws for Linear Motion Systems
  • Rotors for Air Compressors
  • Screws for Hydraulic Pumps
This machine also supports the production of specialized profiles, such as asymmetric profiles and cycloid gears, using precise XY-coordinate inputs.
Enhance Productivity with the G 375 H
  • Short Setup Times:
    Maximize machine uptime with fast changeovers.
  • Integrated Gear Inspection:
    Verify gear quality without additional processes.
  • High Flexibility:
    Produce a wide range of profiles, including helical, spur and asymmetric designs.
Why Choose the G 375 H Horizontal Gear Grinding Machine?
The G 375 H offers the perfect balance of versatility, precision and efficiency, making it a top choice for manufacturers of gears, rotors and screws. With its modular design, advanced technology and exceptional accuracy, this machine adapts to your production needs while delivering consistent, high-quality results.
Ready to Revolutionize Your Gear Manufacturing Process?
Experience the precision and reliability of the G 375 H horizontal gear profile grinding machine from EMAG. Contact us today to learn how this machine can optimize your gear production processes.
优势 G 375 H
  • High Stability and Precision: A rigid machine structure ensures a stable grinding process, with direct-drive and linear motors enhancing accuracy and reliability across all axes.
  • Superior Product Quality: Delivers exceptional precision for gears and components, meeting tight tolerances and with integrated gear inspection.
  • Versatile and Flexible Production: Handles components ranging from 30mm internal gears to large external gears, with quick transitions and minimal setup time.
  • Easy Tool Changes: Simple and efficient tool changes allow for quick adjustments between different gear profiles and components.
  • Customizable to Your Needs: A modular design supports tailored configurations and integrates seamlessly with automation systems for streamlined workflows.
技术数据
Module range
0.5 - 15.0 mm
工件最大直径
375 mm
15 in
工件最大长度
870 mm
34.5 in
Module range mm 0.5 - 15.0
工件最大直径 mm
15
工件最大长度 mm
34.5
Profile depth, max. mm
1.5
1.5 / 13.5
Tool spindle power kW
hp
23
31
Ceramic wheel diameter mm
1.5 / 14
砂轮主轴转速,最 1/min 18,000
工件最大重量 kg
lb
350
771.5
机床重量 kg
lb
11,000
24,251
控制系统 Siemens Simnumerik 840 D sl
